Introduzione
This guide will show you how to remove the front cover of your device. Use this guide to gain access to the button pad and LCD screen.
Parti
Nessuna parte richiesta.
Remove 2 screws (2.5 mm) on the top of the device using Phillips #0.
  • Remove 2 screws (2.5 mm) on the top of the device using Phillips #0.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Remove 2 screws (2.5 mm) on the bottom of the device using a Phillips #0.
  • Remove 2 screws (2.5 mm) on the bottom of the device using a Phillips #0.
Aggiungi Commento
Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen. When the cover has been lifted off the screen, use your hands to remove it from the device. The button pad may fall off when the cover is removed.
  • Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen.
  • When the cover has been lifted off the screen, use your hands to remove it from the device.
  • The button pad may fall off when the cover is removed.
Aggiungi Commento
Conclusione
Gabriele Pregadio
Membro da: 17/04/2013
1 Reputazione
2 Guide realizzate
Cal Poly, Team 17-2, Regan Spring 2013 Membro di Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Membri
8 Guide realizzate
Fantastic but does anyone know where I can get this part?
VegetaFlex4Fitness - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 248
