Cosa ti serve
Slide down the eject button.
Pull out the old SmartMedia Card.
Insert the new SmartMedia Card.
The notched corner of the SmartMedia card should go in the top left corner.
Using a Phillips #00 Screwdriver, remove the two 7.5mm screws from the sides of the back cover.
Using a Phillips #00 Screwdriver, remove the two 5.5mm screws from the sides of the battery compartment.
Using a Phillips #00 Screwdriver, remove the two 5.5mm screws on the left and right edges of the circuit board.
Desolder the seven solder joints which hold the lock switch in place.
Install the new lock/unlock switch.
