Introduzione
The switch is an essential piece of the Craftsman Model 315.10721. Even if the motor and inner hardware is working, if the switch is broken, the saw will not start.
Parti
Nessuna parte richiesta.
Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
  • Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
  • Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
  • Once the five screws are removed, lift the handle cover from the saw.
Aggiungi Commento
Using a Phillips #1 screwdriver, remove the 1/2" silver screw that is securing the switch.
  • Using a Phillips #1 screwdriver, remove the 1/2" silver screw that is securing the switch.
Aggiungi Commento
Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
  • Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
    • The leads are where the black and white wires from the switch are plugged in.
  • Release both sets of the black and white wires and gently pull them from the leads.
  • To install the new switch, insert the wires of the new cord in the same way that they were removed.
Aggiungi Commento
Conclusione
Riley Hilliker
Membro da: 14/10/2014
546 Reputazione
5 Guide realizzate
Cal Poly, Team 4-47, Amido Fall 2014 Membro di Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 388
