Introduzione
Often times it is only necessary to replace the carbon brushes, not the motor. Carbon brushes experience a lot of friction, and replacement is generally expected over time. Ensure your saw is unplugged before beginning the repair
Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor. Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor.
  • Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor.
Aggiungi Commento
Using a Phillips #00 screwdriver or a small diameter nail, carefully pull out the washer.
  • Using a Phillips #00 screwdriver or a small diameter nail, carefully pull out the washer.
    • The washer is seurely held in place and may require force to remove
Aggiungi Commento
After the washers are removed, gently grab the old brushes and remove them from the motor.
  • After the washers are removed, gently grab the old brushes and remove them from the motor.
    • When reassembling make sure the curvature of the brushes match curvature of the motor.
Aggiungi Commento
Conclusione
Riley Hilliker
Membro da: 14/10/2014
546 Reputazione
5 Guide realizzate
Cal Poly, Team 4-47, Amido Fall 2014 Membro di Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 550
