Introduzione
If the battery in your Connect Four has died, you will need to replace it. The Connect Four Electronic Handheld requires 1 AA battery. To access the battery compartment on the back of the device, you will need a Phillips head screwdriver.
Make sure the Connect Four Electronic Handheld is off. There is no off button, so you will need to let it shut off automatically.
  • Make sure the Connect Four Electronic Handheld is off. There is no off button, so you will need to let it shut off automatically.
Aggiungi Commento
Take a Phillips head screwdriver and remove the (9.1mm length) #2 screw in the middle of the battery casing. Slide the cover off and remove the battery.
  • Take a Phillips head screwdriver and remove the (9.1mm length) #2 screw in the middle of the battery casing.
  • Slide the cover off and remove the battery.
Aggiungi Commento
Put in the new AA battery, ensuring that the negative end slides into the spring.
  • Put in the new AA battery, ensuring that the negative end slides into the spring.
Aggiungi Commento
Conclusione
Kamaryn
Membro da: 22/10/2014
201 Reputazione
2 Guide realizzate
Baylor, Team 8-11, Williams Fall 2014 Membro di Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 93
