Introduzione
In order to replace any internal parts, you first need to take off the back panel of the hair dryer. This guide will show you how to do that.
Parti
Nessuna parte richiesta.
Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
  • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
  • Hold the hair dryer by the handle so that the back panel faces up.
Aggiungi Commento
Remove the two 15.875 mm Phillips #2 screws from the back panel. Remove the two 15.875 mm Phillips #2 screws from the back panel.
  • Remove the two 15.875 mm Phillips #2 screws from the back panel.
Aggiungi Commento
Starting from where the cord attaches to the handle, pull apart the two plastic panels. Continue separating the back panel, working along the seam. With moderate force, completely remove the back panel from the hair dryer.
  • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
  • Continue separating the back panel, working along the seam.
  • With moderate force, completely remove the back panel from the hair dryer.
Aggiungi Commento
Conclusione
Timothy Lo
Membro da: 22/04/2014
863 Reputazione
7 Guide realizzate
Cal Poly, Team 10-58, Amido Spring 2014 Membro di Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 59
Tutti i Tempi: 2,554
