Salta al contenuto principale
Compaq Evo N1000v Rear Fan Replacement
Cosa ti serve
  1. Compaq Evo N1000v Rear Fan Replacement, Rear Fan: passo 1, immagine 1 di 1
    • Carefully remove the screws located inside the red circles.
  2. Compaq Evo N1000v Rear Fan Replacement: passo 2, immagine 1 di 2 Compaq Evo N1000v Rear Fan Replacement: passo 2, immagine 2 di 2
    • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
    • Push down on the spudger to lift the LED display upward.
    • Do this on both the left and right sides of the device as shown in the images.
  3. Compaq Evo N1000v Rear Fan Replacement: passo 3, immagine 1 di 1
    • Completely remove the LED display panel from the device.
  4. Compaq Evo N1000v Rear Fan Replacement: passo 4, immagine 1 di 1
    • Lift the keyboard up from the back end as shown in the image.
  5. Compaq Evo N1000v Rear Fan Replacement: passo 5, immagine 1 di 1
    • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
  6. Compaq Evo N1000v Rear Fan Replacement: passo 6, immagine 1 di 1
    • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
    • Repeat this action on the right side of the lock.
  7. Compaq Evo N1000v Rear Fan Replacement: passo 7, immagine 1 di 1
    • Pull the keyboard upward to remove it from the device.
  8. Compaq Evo N1000v Rear Fan Replacement: passo 8, immagine 1 di 1
    • Unscrew the 3 screws as shown in the photo.
  9. Compaq Evo N1000v Rear Fan Replacement: passo 9, immagine 1 di 1
    • Remove the cable with the grip tweezers as shown in the photo.
  10. Compaq Evo N1000v Rear Fan Replacement: passo 10, immagine 1 di 1
    • Remove the rear fan.
    • Repeat these steps in reverse order to install the new rear fan.
Conclusione
ryan
Membro da: 03/12/14
470 Reputazione
2 Guide realizzate
Un commento
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
DeK-Test New - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 395
