Press the eject button to view the laser inside. Using the blue plastic tool and the tweezers, remove the ribbon cable. Using the blue plastic tool and the tweezers, remove the ribbon cable.
  • Press the eject button to view the laser inside.
  • Using the blue plastic tool and the tweezers, remove the ribbon cable.
Aggiungi Commento
Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver. Do not lift the top of the DVD player too quickly because there are wires attached on the inside. Pry the top of the device open from the right side where the buttons are located.
  • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
  • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
  • Pry the top of the device open from the right side where the buttons are located.
Aggiungi Commento
When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them. Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board. Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
  • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
Aggiungi Commento
Remove the two 6.35mm screws circled in black with a #1 Philips head screwdriver. Remove one 4mm screw circled in red with a #1 Philips head screwdriver.
  • Remove the two 6.35mm screws circled in black with a #1 Philips head screwdriver.
  • Remove one 4mm screw circled in red with a #1 Philips head screwdriver.
Aggiungi Commento
There are three small 4.5mm springs that can be easily lost. Be careful when lifting up the railing assembly to make sure you don't lose them. The location of the springs are circled. Using two plastic tool removers, lift the two rails up at an angle. Keep the rods angled as shown.
  • There are three small 4.5mm springs that can be easily lost. Be careful when lifting up the railing assembly to make sure you don't lose them.
  • The location of the springs are circled.
  • Using two plastic tool removers, lift the two rails up at an angle. Keep the rods angled as shown.
  • The rail at the top of the picture is 82mm and the rail at the bottom of the picture is 65mm.
Aggiungi Commento
Be careful not to lose the spring at the top of the laser. Lift the laser assembly out of the fixture.
  • Be careful not to lose the spring at the top of the laser.
  • Lift the laser assembly out of the fixture.
Aggiungi Commento
Remove the rails from the disk reader. Once the top rail is removed, the white gear will come off and under it will be one of the springs. Once the top rail is removed, the white gear will come off and under it will be one of the springs.
  • Remove the rails from the disk reader.
  • Once the top rail is removed, the white gear will come off and under it will be one of the springs.
Aggiungi Commento
Conclusione
Yufay Chow
Membro da: 23/01/2012
92 Reputazione
4 Guide realizzate
Cal Poly, Team 10-36, Amido Winter 2012 Membro di Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 549
