Using a Phillips #00 screwdriver, remove the four 1.1mm long screws from the top side.
  • Using a Phillips #00 screwdriver, remove the four 1.1mm long screws from the top side.
Aggiungi Commento
Using a Phillips #00 screwdriver, remove the four 1.1mm long screws from the bottom side.
  • Using a Phillips #00 screwdriver, remove the four 1.1mm long screws from the bottom side.
  • Remove the warranty sticker across the bottom.
Aggiungi Commento
Gently lift off the back and front casing. The outer shell should easily come apart.
  • Gently lift off the back and front casing.
  • The outer shell should easily come apart.
Aggiungi Commento
Make sure the device screen is face down.
  • Make sure the device screen is face down.
Aggiungi Commento
Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive. Raise the bottom edge of the hard drive 15 degrees up from the device. Raise the bottom edge of the hard drive 15 degrees up from the device.
  • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
  • Raise the bottom edge of the hard drive 15 degrees up from the device.
Aggiungi Commento
Place fingers on the IDE connectors and  gently slide the hard drive out from the   IDE module. Place fingers on the IDE connectors and  gently slide the hard drive out from the   IDE module. Place fingers on the IDE connectors and  gently slide the hard drive out from the   IDE module.
  • Place fingers on the IDE connectors and gently slide the hard drive out from the IDE module.
Aggiungi Commento
Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard. Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard.
  • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard.
Aggiungi Commento
Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
  • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
Aggiungi Commento
Using the plastic opening tool, completely lift the metal bracket off of the motherboard. Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
  • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
  • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
Aggiungi Commento
Using the plastic opening tool, completely lift the ribbon off of the motherboard.
  • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
Aggiungi Commento
Completely remove the IDE connector from the device. The audio jack is attached to the IDE connector.  Pull at a 45 degree angle from the audio jack.
  • Completely remove the IDE connector from the device.
  • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
Aggiungi Commento
Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard. Completely remove the motherboard.
  • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
  • Completely remove the motherboard.
  • The motherboard should slide out easily.
Aggiungi Commento
Set aside the front cover.
  • Set aside the front cover.
  • Flip over the motherboard.
  • Using the Philips #00 screwdriver, remove the three 4mm long screws holding down the button module.
Aggiungi Commento
Using the tweezers, lift up the button module to a 180 degree angle. Leave the button module attached by the ribbon. Flip over the motherboard with the button module still attached.
  • Using the tweezers, lift up the button module to a 180 degree angle.
  • Leave the button module attached by the ribbon.
  • Flip over the motherboard with the button module still attached.
Aggiungi Commento
Fold the button module over the motherboard. Using the tweezers, remove the ribbon pin. The ribbon pin should snap completely off of the motherboard.
  • Fold the button module over the motherboard.
  • Using the tweezers, remove the ribbon pin.
  • The ribbon pin should snap completely off of the motherboard.
Aggiungi Commento
The ribbon should easily detach from the motherboard. The ribbon should easily detach from the motherboard.
  • The ribbon should easily detach from the motherboard.
Aggiungi Commento
Flip over the motherboard so the screen faces up. Carefully slide the battery off of the motherboard.
  • Flip over the motherboard so the screen faces up.
  • Carefully slide the battery off of the motherboard.
  • Leave the battery cable connected to the motherboard.
Aggiungi Commento
Place two fingers on the battery connectors and gently pull the power cable connector completely out from the motherboard. Do not pull directly on the wire as it may damage the connector. Do not pull directly on the wire as it may damage the connector.
  • Place two fingers on the battery connectors and gently pull the power cable connector completely out from the motherboard.
  • Do not pull directly on the wire as it may damage the connector.
Aggiungi Commento
Conclusione
Ryan Sutardji
Membro da: 29/06/2012
171 Reputazione
7 Guide realizzate
Cal Poly, Team 1-4, Regan SU 2012 Membro di Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 972
