Salta al contenuto principale
Charge 3 Battery Replacement
Cosa ti serve
  1. Charge 3 Battery Replacement, Battery: passo 1, immagine 1 di 3 Charge 3 Battery Replacement, Battery: passo 1, immagine 2 di 3 Charge 3 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • It is recommended to let the battery discharge before starting. It's a precaution to prevent the battery from lighting on fire if punctured.
    • Remove both T2 screws
    • Slide off the plastic piece by lifting out and then up
    • Slide plastic and spring assembly off the rail
    • Watch out for the spring on in the band release
  2. Charge 3 Battery Replacement: passo 2, immagine 1 di 3 Charge 3 Battery Replacement: passo 2, immagine 2 di 3 Charge 3 Battery Replacement: passo 2, immagine 3 di 3
    • Heat the glass screen with a blowdryer to soften the adhesives
    • Start the next step on the opposite side of the Fitbit wording below the glass. This is due to the display cables being located there
    • Insert a razor blade between the glass and the body
    • Keep going around the rim of the display until loose
  3. Charge 3 Battery Replacement: passo 3, immagine 1 di 1
    • This is how close those cables get to the edge underneath the Fitbit wording so be careful
  4. Charge 3 Battery Replacement: passo 4, immagine 1 di 3 Charge 3 Battery Replacement: passo 4, immagine 2 di 3 Charge 3 Battery Replacement: passo 4, immagine 3 di 3
    • Lift the display then battery up gently
    • The battery is attached with a little bit of adhesive so lift it gently
    • Remove battery connector
  5. Charge 3 Battery Replacement: passo 5, immagine 1 di 2 Charge 3 Battery Replacement: passo 5, immagine 2 di 2
    • Connect new battery connector
    • Peel the plastic layer off the adhesive backing
    • Put the battery back in place
  6. Charge 3 Battery Replacement: passo 6, immagine 1 di 1
    • Add a thin layer of E-6000 glue around the casing
    • Make sure to cover the entire surface that makes contact with the screen to keep the device waterproof
  7. Charge 3 Battery Replacement: passo 7, immagine 1 di 2 Charge 3 Battery Replacement: passo 7, immagine 2 di 2
    • Flip down the screen and remove any extra glue that squeezes out
    • Take a rubber band and wrap it around the device, this will ensure the display stays in place until the glue cures
    • With the rubber bands on go to step 1 and reverse the steps to reinstall the band release
    • The glue will take between 24 and 72 hours to fully cure
    • When the glue is fully cured remove the rubber bands
    • After all is done you will need to calibrate the battery to do this charge it to 100% then leave it charging for an extra 2 hours use the device until it dies of low power and finally charge it to 100% and it should be good to go
    • And walla you now have a repaired Fitbit Charge 3
Conclusione
Thanks to ShellingRook27's Original Dissasembly I Was Able to Make this Guide And Bring a new life to my old device.
Simon Pepin
Membro da: 03/18/23
404 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 154
Tutti i Tempi: 684
