Introduzione
If the 'on'/'off' switch of the device is stuck in the 'off' position, the device will not turn on. This guide will show how to access and replace the switch from within.
Place the meter face down, so the back panel and screws can be seen.
  • Place the meter face down, so the back panel and screws can be seen.
Aggiungi Commento
Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver. Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
Aggiungi Commento
Remove the back panel of the device by lifting upward.
  • Remove the back panel of the device by lifting upward.
  • Remove the battery from the meter before continuing.
Aggiungi Commento
Remove the four 7mm Phillips screws holding the circuit board in place. Remove the four 7mm Phillips screws holding the circuit board in place.
  • Remove the four 7mm Phillips screws holding the circuit board in place.
Aggiungi Commento
Gently lift the circuit board away from the device casing.
  • Gently lift the circuit board away from the device casing.
  • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
Aggiungi Commento
The 'on'/'off' switch is located directly beneath the dial.
  • The 'on'/'off' switch is located directly beneath the dial.
Aggiungi Commento
Gently remove switch from device by lifting upward.
  • Gently remove switch from device by lifting upward.
  • Either clean or replace switch.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Rebekah Allison
Membro da: 13/10/2014
133 Reputazione
1 Guida realizzata
Clemson, Team 2-4, Benson Fall 2014 Membro di Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 26
Tutti i Tempi: 653
