Parti
Nessuna parte richiesta.
Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
Aggiungi Commento
Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed. Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
Aggiungi Commento
Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. The SIM card slot lies under the battery. Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. The SIM card slot lies under the battery.
  • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. The SIM card slot lies under the battery.
Aggiungi Commento
The old SIM card is removed and replaced with the new one. The phone can be reassembled by following these steps in reverse order.
  • The old SIM card is removed and replaced with the new one. The phone can be reassembled by following these steps in reverse order.
Aggiungi Commento
Conclusione
Geoffrey Mosdell
Membro da: 06/10/2014
813 Reputazione
5 Guide realizzate
USF Tampa, Team 4-7, Brown Fall 2014 Membro di USF Tampa, Team 4-7, Brown Fall 2014
USFT-BROWN-F14S4G7
4 Membri
5 Guide realizzate
Mi celular dice SIM no detectada que puedo hacer
Jerson Vargas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 251
Tutti i Tempi: 7,412
