Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
Aggiungi Commento
Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed. Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
Aggiungi Commento
Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
  • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
Aggiungi Commento
With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws. WARNING: Proceeding beyond this point will void the warranty for this device.
  • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
  • WARNING: Proceeding beyond this point will void the warranty for this device.
Aggiungi Commento
Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
  • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
Aggiungi Commento
There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
  • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
Aggiungi Commento
There is one more Phillips screw remaining. It is located beneath the headphone cover.
  • There is one more Phillips screw remaining. It is located beneath the headphone cover.
Aggiungi Commento
With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
  • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
Aggiungi Commento
With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
  • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
Aggiungi Commento
Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
  • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
Aggiungi Commento
Congratulations. You have successfully disassembled the Caterpillar B15.
  • Congratulations. You have successfully disassembled the Caterpillar B15.
Aggiungi Commento
With the device completely disassembled, the LCD can easily be accessed. It is pictured here, in which it adheres to the front of the motherboard.
  • With the device completely disassembled, the LCD can easily be accessed. It is pictured here, in which it adheres to the front of the motherboard.
Aggiungi Commento
The LCD is held to the board by an adhesive, and will peel away with either a spudger or by hand. Disconnect any ribbon cables if applicable.
  • The LCD is held to the board by an adhesive, and will peel away with either a spudger or by hand. Disconnect any ribbon cables if applicable.
Aggiungi Commento
Installing the new LCD is the reverse of removing the old one. The 2mm 3M adhesive tape listed in the guide is recommended for fixing the new display to the board.
  • Installing the new LCD is the reverse of removing the old one. The 2mm 3M adhesive tape listed in the guide is recommended for fixing the new display to the board.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Geoffrey Mosdell
Membro da: 06/10/2014
831 Reputazione
5 Guide realizzate
USF Tampa, Team 4-7, Brown Fall 2014 Membro di USF Tampa, Team 4-7, Brown Fall 2014
USFT-BROWN-F14S4G7
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 59
Tutti i Tempi: 5,057
