Parti
Nessuna parte richiesta.
  • Open the battery door by sliding it toward the LCD screen.
  • This will reveal a small screw to the left of the memory card slot.
  • Carefully remove the screw (1.77mm).
  • The bottom panel of the camera will become loose. It is connected to the camera by two wires so do not remove completely.
Aggiungi Commento
We have oriented the camera with the lens up and the flash toward you for clear visibility. Use a pair of tweezers to gently move the red and black wires away from the lens.
  • We have oriented the camera with the lens up and the flash toward you for clear visibility.
  • Use a pair of tweezers to gently move the red and black wires away from the lens.
Aggiungi Commento
Using tweezers or finger nails to pull up the brown flaps where the three orange film strips meets the circuit board. Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily. Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily.
  • Using tweezers or finger nails to pull up the brown flaps where the three orange film strips meets the circuit board.
  • Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily.
Aggiungi Commento
  • Pull the circuit board away from the camera.
  • Be careful the circuit board is still attached to the camera by a black film strip.
Aggiungi Commento
  • Gently pull off the plastic cover over the LCD screen
Aggiungi Commento
  • Gently pull the LCD screen away from the camera. Be careful since the screen is still attached to the camera circuit board.
  • You have now completed the guide to remove the the LCD screen.
Aggiungi Commento
Conclusione
Jenn Eberts
Membro da: 10/04/2012
197 Reputazione
2 Guide realizzate
Cal Poly, Team 17-28, Amido Spring 2012 Membro di Cal Poly, Team 17-28, Amido Spring 2012
CPSU-AMIDO-S12S17G28
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 286
