Introduzione
This guide will help you replace the motherboard on a Casio Exilim EX Z55 digital camera.
The motherboard connects all of the main components of the camera like the memory, graphics card, and other hardware. The motherboard essentially tells the other camera components what to do. If the motherboard of your device is broken or defective the camera would not function properly or provide you with the best results.
Turn off your camera when you begin this guide.
Cosa ti serve
Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
Remove the orange ribbon cable by grabbing the white tab with your fingers and pulling gently.
Altre 2 persone hanno completato questa guida.
