Introduzione
This guide will show you how to detach the lens assembly from the camera. You may have to repair or replace a cracked lens or one that won't retract.
Parti
Nessuna parte richiesta.
Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom.
  • Locate 12 screws. Four on the left, four on the right, and four on the bottom.
Aggiungi Commento
Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
  • Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
Aggiungi Commento
Separate the front case from the body of the camera.
  • Separate the front case from the body of the camera.
Aggiungi Commento
Separate the back case from the body of the camera.
  • Separate the back case from the body of the camera.
Aggiungi Commento
Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up. Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up. Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
  • Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
Aggiungi Commento
Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
  • Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
  • Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
Aggiungi Commento
Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
  • Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
Aggiungi Commento
Continue to lift the LCD screen all the way up. Be careful not to rip any wires connecting the LCD screen to the top of the camera.
  • Continue to lift the LCD screen all the way up.
  • Be careful not to rip any wires connecting the LCD screen to the top of the camera.
Aggiungi Commento
Remove the orange ribbon cable by grabbing the white tab and pulling back. Remove the orange ribbon cable by grabbing the white tab and pulling back.
  • Remove the orange ribbon cable by grabbing the white tab and pulling back.
Aggiungi Commento
Remove the two 1.66mm screws on both the bottom and top metal plates, using a #00 Phillips screwdriver. Remove the two 1.66mm screws on both the bottom and top metal plates, using a #00 Phillips screwdriver.
  • Remove the two 1.66mm screws on both the bottom and top metal plates, using a #00 Phillips screwdriver.
Aggiungi Commento
Using the plastic opening tool, pry the battery case clamps (located on front of the camera) so that the bottom portion of the camera will come loose.
  • Using the plastic opening tool, pry the battery case clamps (located on front of the camera) so that the bottom portion of the camera will come loose.
Aggiungi Commento
Once the bottom portion of the camera is removed, stand the camera  upright, bottom portion facing up, then detach the inner orange strip from the motherboard to the lens by inserting the plastic opening tool under the tab and lifting up.
  • Once the bottom portion of the camera is removed, stand the camera upright, bottom portion facing up, then detach the inner orange strip from the motherboard to the lens by inserting the plastic opening tool under the tab and lifting up.
Aggiungi Commento
Fully remove the lens from the motherboard.
  • Fully remove the lens from the motherboard.
  • It will still be attached by wires and a different orange ribbon cable.
  • You can now proceed to repair the existing lens or replace it with a new lens.
Aggiungi Commento
Conclusione
Greg Bucher
Membro da: 19/04/2012
14 Reputazione
1 Guida realizzata
Cal Poly, Team 9-45, Regan Spring 2012 Membro di Cal Poly, Team 9-45, Regan Spring 2012
CPSU-REGAN-S12S9G45
7 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 991
