Salta al contenuto principale
Casio Cassiopeia E-125 Touch Screen Replacement
Cosa ti serve
  1. Casio Cassiopeia E-125 Touch Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the device over to the back side.
  2. Casio Cassiopeia E-125 Touch Screen Replacement: passo 2, immagine 1 di 1
    • Slide the small switch on the back to "MAIN".
  3. Casio Cassiopeia E-125 Touch Screen Replacement: passo 3, immagine 1 di 1
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Casio Cassiopeia E-125 Touch Screen Replacement: passo 4, immagine 1 di 1
    • Pull the black tab to remove the battery.
  5. Casio Cassiopeia E-125 Touch Screen Replacement, Touch Screen: passo 5, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
  6. Casio Cassiopeia E-125 Touch Screen Replacement: passo 6, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
  7. Casio Cassiopeia E-125 Touch Screen Replacement: passo 7, immagine 1 di 1
    • Use a spudger or opening tool to separate the two halves of the case.
  8. Casio Cassiopeia E-125 Touch Screen Replacement: passo 8, immagine 1 di 1
    • Pry the two halves of the case apart with the opening tool.
  9. Casio Cassiopeia E-125 Touch Screen Replacement: passo 9, immagine 1 di 1
    • Potential for device damage. Do not pull apart the wires connecting the outer case.
    • Lay the two halves of the outer case next to the central components as shown.
  10. Casio Cassiopeia E-125 Touch Screen Replacement: passo 10, immagine 1 di 1
    • Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
  11. Casio Cassiopeia E-125 Touch Screen Replacement: passo 11, immagine 1 di 2 Casio Cassiopeia E-125 Touch Screen Replacement: passo 11, immagine 2 di 2
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
Conclusione
Cal Poly, Team 5-4, Forte Spring 2012 Membro di Cal Poly, Team 5-4, Forte Spring 2012
CPSU-FORTE-S12S5G4
6 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,007
