Flip the keyboard upside down so the bottom is angled towards you.
  • Flip the keyboard upside down so the bottom is angled towards you.
Aggiungi Commento
Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
  • Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
Aggiungi Commento
Remove the bottom panel by lifting the bottom panel up and outward from yourself.
  • Remove the bottom panel by lifting the bottom panel up and outward from yourself.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop. Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
  • Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop.
  • Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
Aggiungi Commento
Plug in the soldering iron and place somewhere safe to avoid burning yourself or causing a fire.
  • Plug in the soldering iron and place somewhere safe to avoid burning yourself or causing a fire.
  • Completely unscrew and remove all four screws in the corners of the speaker.
Aggiungi Commento
Pull the speaker out of the keyboard and set on a flat surface to solder safely.
  • Pull the speaker out of the keyboard and set on a flat surface to solder safely.
Aggiungi Commento
Be careful when removing the wires and avoid dripping solder on yourself or the keyboard.
  • Be careful when removing the wires and avoid dripping solder on yourself or the keyboard.
  • Touch soldering iron to solder over the end of the wires, and when the solder melts, pull the wires away from the speaker.
  • Remove the speaker and replace with a new one.
Aggiungi Commento
Strip the wires if you need more clean metal to solder to the speaker.
  • Strip the wires if you need more clean metal to solder to the speaker.
  • Use the soldering iron to melt the solder over the wire to connect them to the speaker.
Aggiungi Commento
Completely screw in the screws back into the original positions on the corner of the speaker.
  • Completely screw in the screws back into the original positions on the corner of the speaker.
Aggiungi Commento
Conclusione
Jimmy Winne
Membro da: 04/10/2012
422 Reputazione
6 Guide realizzate
Cal Poly, Team 9-16, Amido Fall 2012 Membro di Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 56
Tutti i Tempi: 3,316
