Salta al contenuto principale
Casio CTK-501 Keys Replacement
Cosa ti serve
  1. Casio CTK-501 Keys Replacement, Bottom Panel: passo 1, immagine 1 di 2 Casio CTK-501 Keys Replacement, Bottom Panel: passo 1, immagine 2 di 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Keys Replacement: passo 2, immagine 1 di 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Keys Replacement: passo 3, immagine 1 di 2 Casio CTK-501 Keys Replacement: passo 3, immagine 2 di 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Keys Replacement, Keys: passo 4, immagine 1 di 1
    • Completely unscrew and remove the screws holding the broken string of keys in place.
  5. Casio CTK-501 Keys Replacement: passo 5, immagine 1 di 1
    • Pull up the top layer of white keys to remove them from the keyboard.
  6. Casio CTK-501 Keys Replacement: passo 6, immagine 1 di 1
    • Pull up on the last layer of white keys to remove them.
  7. Casio CTK-501 Keys Replacement: passo 7, immagine 1 di 1
    • Push the black keys toward the front of the keyboard and rotate them until they fall out of the keyboard.
Conclusione
Altre 7 persone hanno completato questa guida.
Jimmy Winne
Membro da: 10/04/12
578 Reputazione
6 Guide realizzate
Cal Poly, Team 9-16, Amido Fall 2012 Membro di Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Membri
6 Guide realizzate
4 Commenti
my ctk710 keybord circuit failure.... how to get new circuit in online plg help me
michael Akhil - Replica
Please do you know where to get Casio CTK700/720 (or compatible) complete Keys set replacement?
Thanks in advance!
Fred from Brasil
Luis Frederico - Replica
pliskers@optonline.net
Will replacing keys cure a rattle/chatter that I hear from my middle C and D keys when they are played?
pliskers - Replica
I want to repair my Roland Ex 20 keyboard keys because my middle position two keys are muted.
Jit Ghosh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 43
Tutti i Tempi: 25,234
