Salta al contenuto principale
Canon Powershot SD550 Outer Case Replacement
Cosa ti serve
  1. Canon Powershot SD550 Outer Case Replacement, Outer Case: passo 1, immagine 1 di 1
    • Remove the battery and SD card from the camera.
  2. Canon Powershot SD550 Outer Case Replacement: passo 2, immagine 1 di 1
    • Remove the three 3.8 mm screws from the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 Outer Case Replacement: passo 3, immagine 1 di 3 Canon Powershot SD550 Outer Case Replacement: passo 3, immagine 2 di 3 Canon Powershot SD550 Outer Case Replacement: passo 3, immagine 3 di 3
    • Remove the 3.2 mm screw from the right side of the camera.
    • Remove the 2.2 mm screw from the right side of the camera.
    • One of these screws is hidden under the USB port cover.
    • Lift the side panel off.
    • Remove the 1.8 mm screw from underneath the side panel.
  4. Canon Powershot SD550 Outer Case Replacement: passo 4, immagine 1 di 3 Canon Powershot SD550 Outer Case Replacement: passo 4, immagine 2 di 3 Canon Powershot SD550 Outer Case Replacement: passo 4, immagine 3 di 3
    • Remove the two 2.2 mm screws from the left side of the camera.
    • Lift the plate from the camera.
  5. Canon Powershot SD550 Outer Case Replacement: passo 5, immagine 1 di 3 Canon Powershot SD550 Outer Case Replacement: passo 5, immagine 2 di 3 Canon Powershot SD550 Outer Case Replacement: passo 5, immagine 3 di 3
    • Gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 Outer Case Replacement: passo 6, immagine 1 di 3 Canon Powershot SD550 Outer Case Replacement: passo 6, immagine 2 di 3 Canon Powershot SD550 Outer Case Replacement: passo 6, immagine 3 di 3
    • Remove the front of the camera body.
    • Be sure to keep track of the rubber ring.
Conclusione
Cal Poly, Team 18-23, Garner Spring 2011 Membro di Cal Poly, Team 18-23, Garner Spring 2011
CPSU-GARNER-S11S18G23
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,576
