Introduzione
The lens is used for capturing specific scenes and to feed these scenes into the camera.
Parti
Nessuna parte richiesta.
Slide grey latch to open the battery compartment. Slide grey latch to open the battery compartment.
  • Slide grey latch to open the battery compartment.
Aggiungi Commento
Push orange retaining clip to the right to free battery. Push orange retaining clip to the right to free battery.
  • Push orange retaining clip to the right to free battery.
Aggiungi Commento
Remove battery from the camera.
  • Remove battery from the camera.
Aggiungi Commento
Remove the lanyard.
  • Remove the lanyard.
Aggiungi Commento
Remove the two 2.3mm screws (underneath the name plate) and two 2.8mm screws (next to the threaded tripod mount) from the bottom face of the camera.
  • Remove the two 2.3mm screws (underneath the name plate) and two 2.8mm screws (next to the threaded tripod mount) from the bottom face of the camera.
  • Be careful to keep track of the different screw sizes as you proceed with this guide.
Aggiungi Commento
Remove the single 3.8mm screw from the back face of the camera.
  • Remove the single 3.8mm screw from the back face of the camera.
Aggiungi Commento
Remove the two 2.3mm screws from the right face of the camera.
  • Remove the two 2.3mm screws from the right face of the camera.
Aggiungi Commento
Remove the two 3.2mm screws (outside edge) and two 3.7mm screws (towards middle) from the left side of the camera body.
  • Remove the two 3.2mm screws (outside edge) and two 3.7mm screws (towards middle) from the left side of the camera body.
Aggiungi Commento
Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
Aggiungi Commento
Remove the CF card door from the left side of the camera body. Remove the CF card door from the left side of the camera body.
  • Remove the CF card door from the left side of the camera body.
Aggiungi Commento
Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate. Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate.
  • Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate.
Aggiungi Commento
Remove the front face by sliding it off.
  • Remove the front face by sliding it off.
Aggiungi Commento
Remove the rubber seal that goes over the right side of the viewfinder.
  • Remove the rubber seal that goes over the right side of the viewfinder.
Aggiungi Commento
Remove the two 3.9mm screws that retain the laminated cooper sheet.
  • Remove the two 3.9mm screws that retain the laminated cooper sheet.
Aggiungi Commento
Remove the seven wire connections that connect to the motherboard. Remove the seven wire connections that connect to the motherboard.
  • Remove the seven wire connections that connect to the motherboard.
Aggiungi Commento
Remove the single 3.8mm screw that is on the motherboard.
  • Remove the single 3.8mm screw that is on the motherboard.
Aggiungi Commento
Carefully remove the motherboard from the main frame of the camera body.
  • Carefully remove the motherboard from the main frame of the camera body.
Aggiungi Commento
After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
  • After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
Aggiungi Commento
Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
  • Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
Aggiungi Commento
Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
  • Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
  • Be careful because there are still wire connections attached to the mounting plate which you don't want to remove
Aggiungi Commento
Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
  • Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
Aggiungi Commento
Unsolder the four points at the top of the screen with a soldering iron
  • Unsolder the four points at the top of the screen with a soldering iron
Aggiungi Commento
  • You do not need to unsolder the screen to get to the lens, but follow the rest of the steps to free the screen from the housing plate.
Aggiungi Commento
Remove the card-reader shield by removing the screw at the top of the shield.
  • Remove the card-reader shield by removing the screw at the top of the shield.
Aggiungi Commento
Remove the 2 black screws that attach the battery box to the housing plate. The second picture shows the battery box detached from the housing plate.
  • Remove the 2 black screws that attach the battery box to the housing plate.
  • The second picture shows the battery box detached from the housing plate.
Aggiungi Commento
Remove the three (3.1mm) black screws that were behind the screen and battery box.
  • Remove the three (3.1mm) black screws that were behind the screen and battery box.
Aggiungi Commento
Carefully remove the lens. Remove the bottom side of the lens first before the viewfinder side.
  • Carefully remove the lens.
  • Remove the bottom side of the lens first before the viewfinder side.
  • Be careful of wires and delicate parts.
Aggiungi Commento
Conclusione
Joseph Melo
Membro da: 07/04/2011
111 Reputazione
1 Guida realizzata
Cal Poly, Team 20-70, Walters Spring 2011 Membro di Cal Poly, Team 20-70, Walters Spring 2011
CPSU-WALTERS-S11S20G70
5 Membri
4 Guide realizzate
Camera in the pictures is not Canon Powershot S200
jkovalai - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,424
