Salta al contenuto principale
Canon Powershot A610 Camera Housing Replacement
Cosa ti serve
  1. Canon Powershot A610 Camera Housing Replacement, Batteries: passo 1, immagine 1 di 2 Canon Powershot A610 Camera Housing Replacement, Batteries: passo 1, immagine 2 di 2
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Canon Powershot A610 Camera Housing Replacement: passo 2, immagine 1 di 1
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Canon Powershot A610 Camera Housing Replacement, Camera Housing: passo 3, immagine 1 di 3 Canon Powershot A610 Camera Housing Replacement, Camera Housing: passo 3, immagine 2 di 3 Canon Powershot A610 Camera Housing Replacement, Camera Housing: passo 3, immagine 3 di 3
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Canon Powershot A610 Camera Housing Replacement: passo 4, immagine 1 di 1
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Canon Powershot A610 Camera Housing Replacement: passo 5, immagine 1 di 1
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Canon Powershot A610 Camera Housing Replacement: passo 6, immagine 1 di 2 Canon Powershot A610 Camera Housing Replacement: passo 6, immagine 2 di 2
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Canon Powershot A610 Camera Housing Replacement: passo 7, immagine 1 di 1
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Canon Powershot A610 Camera Housing Replacement: passo 8, immagine 1 di 2 Canon Powershot A610 Camera Housing Replacement: passo 8, immagine 2 di 2
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Canon Powershot A610 Camera Housing Replacement: passo 9, immagine 1 di 2 Canon Powershot A610 Camera Housing Replacement: passo 9, immagine 2 di 2
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Canon Powershot A610 Camera Housing Replacement: passo 10, immagine 1 di 3 Canon Powershot A610 Camera Housing Replacement: passo 10, immagine 2 di 3 Canon Powershot A610 Camera Housing Replacement: passo 10, immagine 3 di 3
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 11-26, Maness Winter 2011 Membro di Cal Poly, Team 11-26, Maness Winter 2011
CPSU-MANESS-W11S11G26
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 23
Tutti i Tempi: 9,062
