Introduzione
Use this guide to remove a broken flash unit from your Canon PowerShot SD870 IS.
Remove the wrist strap, if present.
  • Remove the wrist strap, if present.
  • Remove the lithium-ion battery.
Aggiungi Commento
Remove the two 4 mm Phillips #00 screws on the bottom of the camera. Remove the screw next to the wrist strap attachment. Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
  • Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
  • Remove the screw next to the wrist strap attachment.
  • Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
Note: The PH000 bit from my iFixit toolkit fits the screws better than the PH00 described above. The 00 bit is too pointed to bottom out in the screw and therefore does not engage as well.
wayne - Replica
Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
  • Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
With the camera I was repairing, to remove the front cover as shown below, it was necessary to first remove the two smaller screws on the opposite end of the body from the “A/V OUT DIGITAL” cover. That is . . . the screws shown in step 5 which in my camera also hold the front cover in place (design change apparently).
RWM
wayne - Replica
Pull the front cover from the camera by  using gentle upward pressure. Pull the front cover from the camera by  using gentle upward pressure.
  • Pull the front cover from the camera by using gentle upward pressure.
Aggiungi Commento
Remove the two Phillips #00 screws from the flat end of the camera. Remove the black L-shaped side cover plate.
  • Remove the two Phillips #00 screws from the flat end of the camera.
  • Remove the black L-shaped side cover plate.
  • Remove the silver u-shaped retainer plate.
Aggiungi Commento
Slide the back casing off.
  • Slide the back casing off.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
The first screw that needs to be removed is located on the bottom of the camera, on the left hand side.
  • The first screw that needs to be removed is located on the bottom of the camera, on the left hand side.
    • Using a Phillips #00 screwdriver remove the 0.133in silver screw on the bottom left-hand side.
Aggiungi Commento
The second screw that needs to be removed is located on the top of the camera. Using the same Phillips head screwdriver, remove the last 0.133in silver screw.
  • The second screw that needs to be removed is located on the top of the camera.
    • Using the same Phillips head screwdriver, remove the last 0.133in silver screw.
      • This will detach a silver U-shaped piece that was holding LCD screen on. Remove the piece and put it to the side.
Aggiungi Commento
The LCD screen should now only be attached by the LCD data cable.
  • The LCD screen should now only be attached by the LCD data cable.
    • Lift the screen from the right side and use a small screwdriver or other small opening device to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
      • The LCD should still be connected by the backlight cable.
Aggiungi Commento
To remove the backlight cable, use another small opening device to unlock the backlight cable. Carefully slide out the backlight cable.
  • To remove the backlight cable, use another small opening device to unlock the backlight cable.
    • Carefully slide out the backlight cable.
      • The LCD screen should now be fully detached from the camera body.
Aggiungi Commento
The LCD screen casing is connected by 4 claws located on the top and bottom on the left and right hand side.
  • The LCD screen casing is connected by 4 claws located on the top and bottom on the left and right hand side.
    • Carefully disengage the claws by gently prying them off one by one.
      • Once the claws are disengaged, the back of the casing will still be connected to the front casing by the backlight cable.
    • Carefully peel the backlight cable off of the casing.
Aggiungi Commento
The LCD screen and housing should now be in three pieces:
  • The LCD screen and housing should now be in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD screen back housing
  • The LCD screen itself can now be removed and fixed/replaced.
Aggiungi Commento
With the case and LCD screen removed, you are ready to remove the release button. Begin by using the Philips #00 screwdriver to remove two silver 0.159in screws on the top and front of the camera.
  • With the case and LCD screen removed, you are ready to remove the release button.
    • Begin by using the Philips #00 screwdriver to remove two silver 0.159in screws on the top and front of the camera.
Aggiungi Commento
The top plastic piece holding the release button should be held on only by a red-and-black wire connector to the logic board.
  • The top plastic piece holding the release button should be held on only by a red-and-black wire connector to the logic board.
    • Remove the connector from the logic board and detach the release button housing from the camera.
Aggiungi Commento
With the plastic housing for the release button removed from the camera, use the Philips #00 screwdriver to remove two silver  0.090in screws. The release button can now be removed and fixed or replaced.
  • With the plastic housing for the release button removed from the camera, use the Philips #00 screwdriver to remove two silver 0.090in screws.
  • The release button can now be removed and fixed or replaced.
Aggiungi Commento
Begin by removing two silver  0.080in screw on the left side of the camera.
  • Begin by removing two silver 0.080in screw on the left side of the camera.
Aggiungi Commento
With the case, LCD screen, and release button housing removed, the broken flash unit can be removed and replaced.
  • With the case, LCD screen, and release button housing removed, the broken flash unit can be removed and replaced.
    • Begin by disconnecting the hanging flash/speaker unit from the connector on top of the camera.
Aggiungi Commento
Next, gently disconnect the plastic piece on top of the flash/speaker wiring by prying open the claws on either side.
  • Next, gently disconnect the plastic piece on top of the flash/speaker wiring by prying open the claws on either side.
  • The flash unit can now be removed and replaced.
  • Be careful not to touch the capacitor attached to the flash unit as it may still be holding a charge!
Aggiungi Commento
Conclusione
Sam
Membro da: 15/04/2010
134 Reputazione
5 Guide realizzate
Cal Poly, Team 10-45, Garner Spring 2010 Membro di Cal Poly, Team 10-45, Garner Spring 2010
CPSU-GARNER-S10S10G45
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,729
