Salta al contenuto principale
Canon PowerShot SD850 IS Battery Replacement
  1. Canon PowerShot SD850 IS Battery Replacement, Battery: passo 1, immagine 1 di 3 Canon PowerShot SD850 IS Battery Replacement, Battery: passo 1, immagine 2 di 3 Canon PowerShot SD850 IS Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS Battery Replacement: passo 2, immagine 1 di 2 Canon PowerShot SD850 IS Battery Replacement: passo 2, immagine 2 di 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
Conclusione
To reassemble your device, follow thee instructions in reverse order.
Peter Tran
Membro da: 10/06/10
225 Reputazione
6 Guide realizzate
Cal Poly, Team 20-7, Maness Fall 2010 Membro di Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 27
Tutti i Tempi: 2,986
