Pericolo
Potenzialmente Pericoloso
Possibilità di infortunio se questa procedura non viene seguita correttamente. Prestare attenzione e seguire tutte le avvertenze.
Pericolo
Introduzione
This replacement guide will show you how to access the flash capacitor of the Canon Powershot SD780 IS.
Be extremely careful in dealing with the capacitor as it can store a large electrical charge for a long period of time. The safest way to handle a capacitor is by discharging it. You can make a capacitor discharge tool by following the Constructing a Capacitor Discharge Tool guide.
  • Begin by making sure the camera is turned off and the battery has been removed to avoid any shock injuries.
Aggiungi Commento
Having removed the battery, you can begin removing the outermost screws on the camera to allow for case replacement. There are 5 screws in total. This will require a Philips head # 00 screwdriver. Keep track of where each screw came from in order to avoid complications during the reassemble process.
  • Having removed the battery, you can begin removing the outermost screws on the camera to allow for case replacement. There are 5 screws in total. This will require a Philips head # 00 screwdriver.
  • Keep track of where each screw came from in order to avoid complications during the reassemble process.
  • The screws highlighted by the red circles in the second image (on the left side in the first image) are 2.0 mm long.
Aggiungi Commento
Remove the front panel of the camera case to expose the top left copper strip, and gently pull the strip upward to disconnect from camera.
  • Remove the front panel of the camera case to expose the top left copper strip, and gently pull the strip upward to disconnect from camera.
Aggiungi Commento
Remove the screw on the far left hand side of the camera.
  • Remove the screw on the far left hand side of the camera.
Aggiungi Commento
Now that you have removed all of the screws, carefully pull the case apart at the seem. The case will detach from the camera in two pieces.
  • Now that you have removed all of the screws, carefully pull the case apart at the seem. The case will detach from the camera in two pieces.
Aggiungi Commento
Locate the image stabilizer on the top right of the camera and pry the internal battery away from the camera. Having done this, the internal battery can be removed easily.
  • Locate the image stabilizer on the top right of the camera and pry the internal battery away from the camera. Having done this, the internal battery can be removed easily.
Aggiungi Commento
You have now exposed the internal battery, and you may proceed to exchange the old internal battery for a new one.
  • You have now exposed the internal battery, and you may proceed to exchange the old internal battery for a new one.
Aggiungi Commento
Conclusione
Arlene Ale
Membro da: 13/03/2014
449 Reputazione
4 Guide realizzate
what is the number for the replacement battery?
peterprosser - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 518
