Salta al contenuto principale
Canon PowerShot SD700 LCD screen Replacement
Cosa ti serve
  1. Canon PowerShot SD700 LCD screen Replacement, Outside Case: passo 1, immagine 1 di 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 LCD screen Replacement: passo 2, immagine 1 di 1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 LCD screen Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 LCD screen Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 LCD screen Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 LCD screen Replacement: passo 6, immagine 1 di 1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 LCD screen Replacement, LCD screen: passo 7, immagine 1 di 1
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Canon PowerShot SD700 LCD screen Replacement: passo 8, immagine 1 di 3 Canon PowerShot SD700 LCD screen Replacement: passo 8, immagine 2 di 3 Canon PowerShot SD700 LCD screen Replacement: passo 8, immagine 3 di 3
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Canon PowerShot SD700 LCD screen Replacement: passo 9, immagine 1 di 1
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
Conclusione
Altre 2 persone hanno completato questa guida.
Emilio Rossi
Membro da: 04/07/11
113 Reputazione
3 Guide realizzate
Cal Poly, Team 9-71, Walters Spring 2011 Membro di Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,592
