Salta al contenuto principale
Canon PowerShot SD700 E18 Error Replacement
Cosa ti serve
  1. Canon PowerShot SD700 E18 Error Replacement, Outside Case: passo 1, immagine 1 di 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 E18 Error Replacement: passo 2, immagine 1 di 1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 E18 Error Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 E18 Error Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 E18 Error Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 E18 Error Replacement: passo 6, immagine 1 di 1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Attrezzo utilizzato in questo passaggio:
    Dust Blower
    Compra
    • Clean the lens and the area surrounding the lens with a soft brush and dust blower.
    • Tweezers can be helpful when removing sand.
    • Reassemble the camera and if the E18 error persists, further disassembly of the camera may be required.
Conclusione
To reassemble your device, follow steps 1-6 instructions in reverse order.
Aaron Lee
Membro da: 04/07/11
212 Reputazione
3 Guide realizzate
Cal Poly, Team 9-71, Walters Spring 2011 Membro di Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,908
