Introduzione
The lens is the device that focuses the image seen by a camera. Because it is the only moving part, it can easily malfunction, causing blurry pictures or even a camera error.
Parti
Nessuna parte richiesta.
Slide open the battery cover.
  • Slide open the battery cover.
  • Push the small orange tab to the side so the battery can be removed.
Aggiungi Commento
Slide the battery out of the battery compartment. Slide the battery out of the battery compartment.
  • Slide the battery out of the battery compartment.
Aggiungi Commento
Two Phillips screws need to be removed  using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing.  the lower screw is visible on the panel. The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
  • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
  • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
  • When looking at the back of the camera, these two screws are on the right panel of the camera.
Aggiungi Commento
Remove the right side cover from the camera casing.
  • Remove the right side cover from the camera casing.
Aggiungi Commento
Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
Aggiungi Commento
Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
Aggiungi Commento
Remove the left side cover from the camera.
  • Remove the left side cover from the camera.
Aggiungi Commento
Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
Aggiungi Commento
Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it. Remove the internal camera components and layout out all pieces on a clean surface.
  • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
  • Remove the internal camera components and layout out all pieces on a clean surface.
  • The front and back cover may require gentle rocking to remove.
Aggiungi Commento
Carefully wedge the pry tool under the ribbon in the ribbon gate.
  • Carefully wedge the pry tool under the ribbon in the ribbon gate.
  • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
  • Be careful not to damage the ribbon.
Aggiungi Commento
Gently press the ribbon back to get access to a Phillips screw behind it.
  • Gently press the ribbon back to get access to a Phillips screw behind it.
  • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
Aggiungi Commento
Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab. Be careful not to damage the ribbon. Pull the button board away from the rest of the camera.
  • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
  • Pull the button board away from the rest of the camera.
Aggiungi Commento
Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
  • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
Aggiungi Commento
Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
  • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
  • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
Aggiungi Commento
Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board. Be careful not to damage the ribbon.
  • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
  • The LCD can now be completely removed from the camera.
Aggiungi Commento
Place the pry tool under ribbon gate and gently lift it up, disconnecting the ribbon.
  • Place the pry tool under ribbon gate and gently lift it up, disconnecting the ribbon.
Aggiungi Commento
Unscrew three .15 inch Phillips screws from the back of the camera using a #00 Phillips screwdriver.
  • Unscrew three .15 inch Phillips screws from the back of the camera using a #00 Phillips screwdriver.
Aggiungi Commento
Use the pry tool to gently lift the image sensor away from the rest of the camera. Be careful not to damage the image sensor as you pry it up.
  • Use the pry tool to gently lift the image sensor away from the rest of the camera.
  • Be careful not to damage the image sensor as you pry it up.
Aggiungi Commento
Arrange camera so it is facing up towards you.
  • Arrange camera so it is facing up towards you.
  • Unscrew one .01 inch Phillips screw using a #00 Phillips screwdriver from the front of the camera.
Aggiungi Commento
Gently remove the indicated ribbon from respective ribbon gates.
  • Gently remove the indicated ribbon from respective ribbon gates.
Aggiungi Commento
Place spudger under white connector and gently lift it vertically out of its slot.
  • Place spudger under white connector and gently lift it vertically out of its slot.
  • Be careful not to damage wire connector during removal.
Aggiungi Commento
Unscrew three .065 inch Phillips screws using a #00 Phillips screwdriver from the back of the camera.
  • Unscrew three .065 inch Phillips screws using a #00 Phillips screwdriver from the back of the camera.
Aggiungi Commento
Gently pull away flash bulb assembly from the rest of the camera.
  • Gently pull away flash bulb assembly from the rest of the camera.
  • Be careful not to damage the ribbon on the rest of the camera.
Aggiungi Commento
Unscrew three .12 inch long Phillips screws using a #00 Phillips screwdriver from the back of the camera.
  • Unscrew three .12 inch long Phillips screws using a #00 Phillips screwdriver from the back of the camera.
Aggiungi Commento
Gently remove zoom lens from the rest of the camera.
  • Gently remove zoom lens from the rest of the camera.
  • Be careful not to damage ribbon during removal.
Aggiungi Commento
Conclusione
Taylor Shields
Membro da: 13/10/2014
831 Reputazione
8 Guide realizzate
Clemson, Team 2-1, Benson Fall 2014 Membro di Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 253
