Introduzione
The button contact panel is necessary to perform all functions on the Powershot SD 500 Digital ELPH camera. If the button contact panel is not working, the camera is essentially useless.
Cosa ti serve
Slide open the battery cover.
Push the small orange tab to the side so the battery can be removed.
Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
Carefully wedge the pry tool under the ribbon in the ribbon gate.
Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
