Introduzione
This guide shows the user how to take out the logic board, and therefore have the opportunity to replace a defective board.
Parti
Nessuna parte richiesta.
Remove the battery and SD Card from their slots.  Leaving these in could cause the battery to ground and ruin the electronics.
  • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
  • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
Aggiungi Commento
Pull the lanyard mount off of the camera using a spudger or your fingers.
  • Pull the lanyard mount off of the camera using a spudger or your fingers.
Aggiungi Commento
Find the line that separates the casing into its two halves.  Hold each half seperately, and gently pull apart. Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  • Find the line that separates the casing into its two halves. Hold each half seperately, and gently pull apart.
  • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
Aggiungi Commento
Take hold of the inside of the camera, and gently pull away from the back casing.
  • Take hold of the inside of the camera, and gently pull away from the back casing.
Aggiungi Commento
Remove the square, clear, rubber protector from the front of the logic board.  This is not necessary to remove, but can easily fall off and get lost during later steps.
  • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
Aggiungi Commento
When you reassemble the camera, make sure the switch on the casing (pictured left) matches the position of the switch on the camera internals.
  • When you reassemble the camera, make sure the switch on the casing (pictured left) matches the position of the switch on the camera internals.
  • The black viewfinder padding (pictured right) can easily fall off the casing. Make sure you don't lose it when moving around parts.
Aggiungi Commento
Remove the LCD cable by gently prying the hinge open with a spudger or your finger. The cable should easily slide out.
  • Remove the LCD cable by gently prying the hinge open with a spudger or your finger. The cable should easily slide out.
Aggiungi Commento
Lift up the metallic-colored clip with the spudger to remove the shutter panel.
  • Lift up the metallic-colored clip with the spudger to remove the shutter panel.
Aggiungi Commento
Remove the shutter panel with the spudger, now that the clip is released.
  • Remove the shutter panel with the spudger, now that the clip is released.
Aggiungi Commento
Use the spudger or your finger to release the orange ribbon from the logic board.
  • Use the spudger or your finger to release the orange ribbon from the logic board.
Aggiungi Commento
Pull the ribbon out of the socket using the spudger or your finger.
  • Pull the ribbon out of the socket using the spudger or your finger.
  • Disconnect the two other ribbons from the logic board in the same fashion.
Aggiungi Commento
Lift up the large green flap by using the spudger to pry up top right yellow edge.
  • Lift up the large green flap by using the spudger to pry up top right yellow edge.
Aggiungi Commento
Pull the flap back with the spudger so that the logic board is exposed.
  • Pull the flap back with the spudger so that the logic board is exposed.
Aggiungi Commento
Use the screwdriver to remove the three screws on the logic board. Take note that the bottom right screw is shorter than the other two.
  • Use the screwdriver to remove the three screws on the logic board. Take note that the bottom right screw is shorter than the other two.
Aggiungi Commento
Use the spudger to carefully remove the logic board from behind.
  • Use the spudger to carefully remove the logic board from behind.
Aggiungi Commento
Remove the detached logic board from the camera.
  • Remove the detached logic board from the camera.
Aggiungi Commento
Conclusione
Chris Wren
Membro da: 11/04/2010
51 Reputazione
1 Guida realizzata
Cal Poly, Team 25-85, Amido Spring 2010 Membro di Cal Poly, Team 25-85, Amido Spring 2010
CPSU-AMIDO-S10S25G85
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,912
