Introduzione
Removing the LCD screen for replacement.
Parti
Nessuna parte richiesta.
Remove the battery and SD Card from their slots.  Leaving these in could cause the battery to ground and ruin the electronics.
  • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
  • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
Aggiungi Commento
Pull the lanyard mount off of the camera using a spudger or your fingers.
  • Pull the lanyard mount off of the camera using a spudger or your fingers.
Aggiungi Commento
Find the line that separates the casing into its two halves.  Hold each half seperately, and gently pull apart. Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  • Find the line that separates the casing into its two halves. Hold each half seperately, and gently pull apart.
  • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
Aggiungi Commento
Take hold of the inside of the camera, and gently pull away from the back casing.
  • Take hold of the inside of the camera, and gently pull away from the back casing.
Aggiungi Commento
Remove the square, clear, rubber protector from the front of the logic board.  This is not necessary to remove, but can easily fall off and get lost during later steps.
  • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
Aggiungi Commento
When you reassemble the camera, make sure the switch on the casing (pictured left) matches the position of the switch on the camera internals.
  • When you reassemble the camera, make sure the switch on the casing (pictured left) matches the position of the switch on the camera internals.
  • The black viewfinder padding (pictured right) can easily fall off the casing. Make sure you don't lose it when moving around parts.
Aggiungi Commento
Pull the retaining clip up with the spudger or your finger and remove the ribbon from the socket. Pull the retaining clip up with the spudger or your finger and remove the ribbon from the socket.
  • Pull the retaining clip up with the spudger or your finger and remove the ribbon from the socket.
Aggiungi Commento
Remove the tripod mount screw.
  • Remove the tripod mount screw.
  • Turn the camera around so that the screen is facing you, and the camera is upright.
Aggiungi Commento
Remove the screw at the top right of the screen.
  • Remove the screw at the top right of the screen.
Aggiungi Commento
Lift up the screen to reveal the tripod mount screw.
  • Lift up the screen to reveal the tripod mount screw.
Aggiungi Commento
Remove the last screw holding the tripod mount to the case. The LCD ribbon threads under the mount, so upon reinstallation, the ribbon will need to be threaded through before the mount is reattached. Take note of the tripod mount orientation.
  • Remove the last screw holding the tripod mount to the case. The LCD ribbon threads under the mount, so upon reinstallation, the ribbon will need to be threaded through before the mount is reattached. Take note of the tripod mount orientation.
Aggiungi Commento
Pull the back light ribbon from it's socket to remove the LCD completely. There is a little hole you can stick the spudger into to help release the ribbon.
  • Pull the back light ribbon from it's socket to remove the LCD completely. There is a little hole you can stick the spudger into to help release the ribbon.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 25-85, Amido Spring 2010 Membro di Cal Poly, Team 25-85, Amido Spring 2010
CPSU-AMIDO-S10S25G85
4 Membri
5 Guide realizzate
Followed the steps and replaced the broken screen. Now I get only a white screen when turning the camera on. It does take pictures but it won't show anything but a little red dotted arrow on the right hand side over the white screen. Do you have a clue of what is happening?
Roberto - Replica
Salve, dove posso acquistare un display?
Germano Tinari - Replica
Salve, sapreste dirmi dove posso acquistare un display?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 6,205
