Salta al contenuto principale
Canon PowerShot SD1000 Shutter Button Replacement
Cosa ti serve
  1. Canon PowerShot SD1000 Shutter Button Replacement, Back Panel: passo 1, immagine 1 di 2 Canon PowerShot SD1000 Shutter Button Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Shutter Button Replacement: passo 2, immagine 1 di 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Shutter Button Replacement: passo 3, immagine 1 di 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Shutter Button Replacement: passo 4, immagine 1 di 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Shutter Button Replacement: passo 5, immagine 1 di 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Shutter Button Replacement, Front Case: passo 6, immagine 1 di 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Shutter Button Replacement: passo 7, immagine 1 di 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Shutter Button Replacement, Shutter Button: passo 8, immagine 1 di 2 Canon PowerShot SD1000 Shutter Button Replacement, Shutter Button: passo 8, immagine 2 di 2
    • Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
Conclusione
Cal Poly, Team 8-18, Maness Winter 2012 Membro di Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,131
