Parti
Nessuna parte richiesta.
Remove the two screws from the side panel closest to the camera lens. Note: These screws are 2.9 mm long.
  • Remove the two screws from the side panel closest to the camera lens.
  • Note: These screws are 2.9 mm long.
Aggiungi Commento
Remove the two screws from the camera bottom panel.
  • Remove the two screws from the camera bottom panel.
Aggiungi Commento
Remove the 2 screws from the side panel farthest from the lens.
  • Remove the 2 screws from the side panel farthest from the lens.
Aggiungi Commento
Pull the back panel away from the camera body, starting at the end with the function buttons.
  • Pull the back panel away from the camera body, starting at the end with the function buttons.
Aggiungi Commento
Remove the small cover panel and attached wrist strap mount.
  • Remove the small cover panel and attached wrist strap mount.
Aggiungi Commento
Remove the front cover by gently pulling it away from the camera body.
  • Remove the front cover by gently pulling it away from the camera body.
Aggiungi Commento
Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Aggiungi Commento
Conclusione
Phillip Phung
Membro da: 19/01/2012
486 Reputazione
9 Guide realizzate
Cal Poly, Team 8-18, Maness Winter 2012 Membro di Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,016
