Introduzione
Use this guide to replace the front panel of the camera as well as the battery door.
Place camera LCD side up and press up on the battery door. Let it swing open until you can see the battery inside.
  • Place camera LCD side up and press up on the battery door.
  • Let it swing open until you can see the battery inside.
Aggiungi Commento
Press down on the orange plastic.
  • Press down on the orange plastic.
  • This will gently eject the battery from its compartment.
Aggiungi Commento
Holding the edges, slide out the battery. Holding the edges, slide out the battery.
  • Holding the edges, slide out the battery.
Aggiungi Commento
Look at the camera from the side with the lanyard and 4 screws.
  • Look at the camera from the side with the lanyard and 4 screws.
    • Remove the two 3.4 mm screws on the metallic colored part.
Aggiungi Commento
Remove the 3mm screw on the top left.
  • Remove the 3mm screw on the top left.
    • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
  • Now remove the 5.3mm screw on the bottom.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Place the camera LCD side down.
  • Place the camera LCD side down.
  • Remove the two 5.3mm screws by the battery door.
Aggiungi Commento
Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
  • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
    • Make sure to keep these screws separate from the previous 5.3 mm screws.
Aggiungi Commento
Stand the camera back up.
  • Stand the camera back up.
  • Remove the two 3.6mm screws on the side with the A/V Out port.
Aggiungi Commento
Lift open the rubber flap covering the A/V Out port.
  • Lift open the rubber flap covering the A/V Out port.
    • Remove the 3.4mm screw in the center.
    • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
Aggiungi Commento
Use a spudger and gently open up the front panel of the camera.
  • Use a spudger and gently open up the front panel of the camera.
    • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
Aggiungi Commento
There will be a brown plastic piece keeping the thin plastic ribbon in place.
  • There will be a brown plastic piece keeping the thin plastic ribbon in place.
  • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
Aggiungi Commento
Use a pair of tweezers and remove the metal piece inside the camera.
  • Use a pair of tweezers and remove the metal piece inside the camera.
Aggiungi Commento
Remove the battery door
  • Remove the battery door
    • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
Aggiungi Commento
Conclusione
Karim
Membro da: 12/04/2012
24 Reputazione
3 Guide realizzate
Cal Poly, Team 7-34, Maness Spring 2012 Membro di Cal Poly, Team 7-34, Maness Spring 2012
CPSU-MANESS-S12S7G34
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 841
