Introduzione
Did the LCD Screen on your Canon PowerShot S410 stop working so you can no longer see the images you are trying to photograph on the back of your camera?
Follow this step-by-step guide to help repair your LCD screen so you can get back to taking those photos!
Cosa ti serve
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
Remove the two 3.8mm screws near the strap bracket.
Remove the small panel covering the mounting bracket.
Remove the door covering the memory card.
A fingernail or spudger can be used to remove the plastic flap covering the motherboard.
