Introduzione
This guide demonstrates how to remove and replace the battery pack.
Turn the camera with the bottom side facing up. Locate the panel labeled "Batt. Open"
  • Turn the camera with the bottom side facing up.
  • Locate the panel labeled "Batt. Open"
  • Place your finger on the panel and slide it in the direction of the arrow.
  • The slot will swing open revealing the battery pack.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Rotate the camera so that the slot is horizontal.
  • Rotate the camera so that the slot is horizontal.
  • Pull the orange lever and the battery will spring out slightly.
Aggiungi Commento
Grasp battery and fully pull out of slot
  • Grasp battery and fully pull out of slot
  • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
Aggiungi Commento
Conclusione
After a new battery has been inserted, close the swinging door and you're done.
Randy Lormand
Membro da: 23/01/2011
331 Reputazione
3 Guide realizzate
Cal Poly, Team 11-27, Maness Winter 2011 Membro di Cal Poly, Team 11-27, Maness Winter 2011
CPSU-MANESS-W11S11G27
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,335
