Introduzione
This guide will show you how to remove the front and back casing of the camera.
Parti
Nessuna parte richiesta.
On the bottom of the camera, use your thumb to press the rubber battery cover towards the side of the camera with the strap base. The cover will shift to extend beyond the rest of the camera.
  • On the bottom of the camera, use your thumb to press the rubber battery cover towards the side of the camera with the strap base. The cover will shift to extend beyond the rest of the camera.
Aggiungi Commento
Hold the end of the battery cover that extends beyond the camera and lift it up.
  • Hold the end of the battery cover that extends beyond the camera and lift it up.
Aggiungi Commento
Pull back on the orange tab to release the battery.
  • Pull back on the orange tab to release the battery.
Aggiungi Commento
Pull the battery out.
  • Pull the battery out.
Aggiungi Commento
Locate the sliding button labeled "CF open" on the back of the camera. Press and slide down the button labeled "CF open". The memory card cover will pop open. Press and slide down the button labeled "CF open". The memory card cover will pop open.
  • Locate the sliding button labeled "CF open" on the back of the camera.
  • Press and slide down the button labeled "CF open". The memory card cover will pop open.
Aggiungi Commento
Push down on the black square button next to the memory card slot. This will release the memory card from the slot. Push down on the black square button next to the memory card slot. This will release the memory card from the slot. Push down on the black square button next to the memory card slot. This will release the memory card from the slot.
  • Push down on the black square button next to the memory card slot. This will release the memory card from the slot.
Aggiungi Commento
Pull the memory card out of the memory card slot. Pull the memory card out of the memory card slot.
  • Pull the memory card out of the memory card slot.
Aggiungi Commento
Remove two 2.4mm Phillips screws from the right side of the camera.
  • Remove two 2.4mm Phillips screws from the right side of the camera.
Aggiungi Commento
Remove two 2.4mm Phillips screws above the label on the bottom of the camera.
  • Remove two 2.4mm Phillips screws above the label on the bottom of the camera.
  • Remove two 2.8mm Phillips screws next to the tripod hole.
Aggiungi Commento
Remove the two 3.2mm Phillips screws that are closer to the top and bottom edges of the camera.
  • Remove the two 3.2mm Phillips screws that are closer to the top and bottom edges of the camera.
  • Remove the two 3.8mm Phillips screws on either side of the strap base.
Aggiungi Commento
Remove one 1.6mm Phillips screw from the above the CF open button on back of the camera.
  • Remove one 1.6mm Phillips screw from the above the CF open button on back of the camera.
Aggiungi Commento
Gently pull the front casing from the camera. The following items will either fall off or will be loose: the strap base, the gray rubber cover labeled "Digital A/V Out", and the black rubber piece over the view finder. Remove the memory card cover by sliding down the CF open button and moving the pin.
  • Gently pull the front casing from the camera.
  • The following items will either fall off or will be loose: the strap base, the gray rubber cover labeled "Digital A/V Out", and the black rubber piece over the view finder.
  • Remove the memory card cover by sliding down the CF open button and moving the pin.
Aggiungi Commento
Gently pull the back casing from the camera. Gently pull the back casing from the camera.
  • Gently pull the back casing from the camera.
Aggiungi Commento
Conclusione
Tanya Malalang
Membro da: 12/01/2011
325 Reputazione
3 Guide realizzate
Cal Poly, Team 13-1, Forte Winter 2011 Membro di Cal Poly, Team 13-1, Forte Winter 2011
CPSU-FORTE-W11S13G1
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,583
