Introduzione
Use this guide to replace the Canon Powershot A75's speaker unit.
Parti
Nessuna parte richiesta.
Turn the camera over and locate the "BATT OPEN" sliding switch.
  • Turn the camera over and locate the "BATT OPEN" sliding switch.
Aggiungi Commento
Slide the switch to the right. The battery cover should slide down and spring open. The battery cover should slide down and spring open.
  • Slide the switch to the right.
    • The battery cover should slide down and spring open.
Aggiungi Commento
Remove the 4 AA batteries. Watch for the orientation of the batteries as they slide out. The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
Aggiungi Commento
Open the memory card slot by sliding it laterally until you hear a click Remove the 5.9mm screw in the upper corner of the memory card slot
  • Open the memory card slot by sliding it laterally until you hear a click
  • Remove the 5.9mm screw in the upper corner of the memory card slot
Aggiungi Commento
Remove the two 4.1mm screws at the bottom of the battery flap.
  • Remove the two 4.1mm screws at the bottom of the battery flap.
Aggiungi Commento
Lift the shutter button and speaker part from the top of the camera. Do not pull the part too hard because there is a plug connecting the speaker to the camera.
  • Lift the shutter button and speaker part from the top of the camera.
    • Do not pull the part too hard because there is a plug connecting the speaker to the camera.
Aggiungi Commento
Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out. Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out. Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
Aggiungi Commento
Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
  • Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
  • Remove the glue and unsolder the speaker from the outer casing. Replace or repair the speaker as necessary.
Aggiungi Commento
Conclusione
Austin Fox
Membro da: 11/04/2012
1 Reputazione
2 Guide realizzate
Cal Poly, Team 17-30, Amido Spring 2012 Membro di Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 265
