Introduzione
Use this guide to replace the Canon PowerShot A75's flash unit.
Turn the camera over and locate the "BATT OPEN" sliding switch.
  • Turn the camera over and locate the "BATT OPEN" sliding switch.
Aggiungi Commento
Slide the switch to the right. The battery cover should slide down and spring open. The battery cover should slide down and spring open.
  • Slide the switch to the right.
    • The battery cover should slide down and spring open.
Aggiungi Commento
Remove the 4 AA batteries. Watch for the orientation of the batteries as they slide out. The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
Aggiungi Commento
Remove the three 2.5mm screws on the bottom of the camera.
  • Remove the three 2.5mm screws on the bottom of the camera.
Aggiungi Commento
Remove the 3.8mm screw underneath the flap that covers the A/V port.
  • Remove the 3.8mm screw underneath the flap that covers the A/V port.
Aggiungi Commento
Remove the 2.4mm screw located underneath the cover of the memory card slot. Remove the 2.4mm screw located underneath the cover of the memory card slot.
  • Remove the 2.4mm screw located underneath the cover of the memory card slot.
Aggiungi Commento
Open the memory card slot by sliding it laterally until you hear a click. Remove the 5.9mm screw in the upper corner of the memory card slot.
  • Open the memory card slot by sliding it laterally until you hear a click.
  • Remove the 5.9mm screw in the upper corner of the memory card slot.
Aggiungi Commento
Remove the two 4.1mm screws at the bottom of the battery flap.
  • Remove the two 4.1mm screws at the bottom of the battery flap.
Aggiungi Commento
Lift the shutter button and speaker part from the top of the camera. DO NOT pull the part too hard because there is a plug connecting the speaker to the camera.
  • Lift the shutter button and speaker part from the top of the camera.
    • DO NOT pull the part too hard because there is a plug connecting the speaker to the camera.
Aggiungi Commento
Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out. Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out. Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
Aggiungi Commento
Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
  • Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
Aggiungi Commento
Separate the back casing and front casing of the camera using your hands. Pulling the two halves apart can be difficult, especially at the top. Use a moderate amount of force. Pulling the two halves apart can be difficult, especially at the top. Use a moderate amount of force.
  • Separate the back casing and front casing of the camera using your hands.
    • Pulling the two halves apart can be difficult, especially at the top. Use a moderate amount of force.
Aggiungi Commento
On the front of the camera, press the button on the lower left of the lens. Twist the outer lens casing counter-clockwise and slide it out. Twist the outer lens casing counter-clockwise and slide it out.
  • On the front of the camera, press the button on the lower left of the lens.
  • Twist the outer lens casing counter-clockwise and slide it out.
Aggiungi Commento
Take off the front casing. There is a black rubber washer around the lens that comes out after you take the casing off. Make sure to replace it when putting the camera back together. There is a black rubber washer around the lens that comes out after you take the casing off. Make sure to replace it when putting the camera back together.
  • Take off the front casing.
  • There is a black rubber washer around the lens that comes out after you take the casing off. Make sure to replace it when putting the camera back together.
Aggiungi Commento
Rotate the camera such that the flash unit and capacitor are facing you. DO NOT touch the capacitor because it may shock you. Remove the 3.5mm screw located between the flash unit and the capacitor.
  • Rotate the camera such that the flash unit and capacitor are facing you.
    • DO NOT touch the capacitor because it may shock you.
  • Remove the 3.5mm screw located between the flash unit and the capacitor.
Aggiungi Commento
Snap flash unit out of place with your fingers. Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
  • Snap flash unit out of place with your fingers.
    • Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
  • Unsolder the five wires connected to the flash unit in order to remove it.
Aggiungi Commento
Conclusione
Chris Miyahira
Membro da: 12/04/2012
38 Reputazione
1 Guida realizzata
Cal Poly, Team 17-30, Amido Spring 2012 Membro di Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 569
