Parti
Nessuna parte richiesta.
Unscrew the three Phillips #00 1.6x3mm screws on the side. Lift loose panel from the case. Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  • Unscrew the three Phillips #00 1.6x3mm screws on the side.
  • Lift loose panel from the case.
  • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
Aggiungi Commento
Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
Aggiungi Commento
Open the battery door.
  • Open the battery door.
  • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
Aggiungi Commento
Lift the terminal cover on the side of the camera. Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  • Lift the terminal cover on the side of the camera.
  • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
Aggiungi Commento
Gently pull the top panel to separate it from the case.
  • Gently pull the top panel to separate it from the case.
  • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
Aggiungi Commento
Gently pull the front panel to separate it from the camera. The battery terminals are easy to access from this step.
  • Gently pull the front panel to separate it from the camera.
  • The battery terminals are easy to access from this step.
Aggiungi Commento
Gently pull the terminal cover to separate it from the camera. Gently pull the terminal cover to separate it from the camera.
  • Gently pull the terminal cover to separate it from the camera.
Aggiungi Commento
Slide the memory card cover down. Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  • Slide the memory card cover down.
  • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
Aggiungi Commento
Gently pull the back panel to separate it from the camera. Gently pull the back panel to separate it from the camera.
  • Gently pull the back panel to separate it from the camera.
Aggiungi Commento
Unscrew the Phillips #00 1.6x3mm screw located on the top panel. Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
  • Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
Aggiungi Commento
Gently lift the metal plate and move it to the side.
  • Gently lift the metal plate and move it to the side.
Aggiungi Commento
Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button. Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
  • Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
Aggiungi Commento
The trigger button will fall off once the screws have been removed.
  • The trigger button will fall off once the screws have been removed.
Aggiungi Commento
Conclusione
Jaime Abraham
Membro da: 08/09/2014
335 Reputazione
3 Guide realizzate
CSU Fullerton, Team 1-1, Bruce Fall 2014 Membro di CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 553
