Introduzione
This guide demonstrates how to take off the camera casing and easily pop the broken button back into place.
Parti
Nessuna parte richiesta.
Unlock the battery cover, while swinging  the cover outward to open it. Unlock the battery cover, while swinging  the cover outward to open it.
  • Unlock the battery cover, while swinging the cover outward to open it.
Aggiungi Commento
Turn the camera over and allow the batteries to fall out.
  • Turn the camera over and allow the batteries to fall out.
  • Close the battery cover.
Aggiungi Commento
Remove the three 3 mm screws that attach the side panel to the body of the camera. Using your fingernails, pull the side panel outward to remove it. Remove the two remaining 2 mm screws that attach to the frame of the camera.
  • Remove the three 3 mm screws that attach the side panel to the body of the camera.
  • Using your fingernails, pull the side panel outward to remove it.
  • Remove the two remaining 2 mm screws that attach to the frame of the camera.
Aggiungi Commento
Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
  • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
  • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
Aggiungi Commento
Open the battery cover.
  • Open the battery cover.
  • Remove the 5 mm screw that sits on the top of the battery slot.
  • Remove the three 6 mm screws that sit at the bottom of the battery slot.
Aggiungi Commento
Open the digital A/V DC terminal cover. Remove the three 4 mm screws.
  • Open the digital A/V DC terminal cover.
  • Remove the three 4 mm screws.
  • Detach the digital A/V DC terminal.
  • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
Aggiungi Commento
Grip the sides of the top cover and gently lift the cover until it detaches from the camera.
  • Grip the sides of the top cover and gently lift the cover until it detaches from the camera.
  • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
Aggiungi Commento
Open the battery cover. With the camera upside down, pull the  front case's side that is closest to you, in an  outward movement.
  • With the camera upside down, pull the front case's side that is closest to you, in an outward movement.
  • Apply some force, but pull it gently to prevent damage.
Aggiungi Commento
Open the memory card slot cover. Remove the 3 mm screw that sits near the bottom of the case.
  • Open the memory card slot cover.
  • Remove the 3 mm screw that sits near the bottom of the case.
Aggiungi Commento
Flip the LCD screen all the way open. Grip both sides of the back case's top and gently pull it, in an outward movement, until the case detaches. Grip both sides of the back case's top and gently pull it, in an outward movement, until the case detaches.
  • Flip the LCD screen all the way open.
  • Grip both sides of the back case's top and gently pull it, in an outward movement, until the case detaches.
Aggiungi Commento
Remove the back casing. Flip the casing over and push on the back of the broken button with either your finger or a blunt object until it realigns into its slot.
  • Remove the back casing.
  • Flip the casing over and push on the back of the broken button with either your finger or a blunt object until it realigns into its slot.
Aggiungi Commento
Conclusione
Matthew Ramirez
Membro da: 20/01/2011
620 Reputazione
5 Guide realizzate
Cal Poly, Team 11-26, Maness Winter 2011 Membro di Cal Poly, Team 11-26, Maness Winter 2011
CPSU-MANESS-W11S11G26
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 4,792
