Salta al contenuto principale
Canon PowerShot A550 SD Card Reader
Cosa ti serve
  1. Canon PowerShot A550 SD Card Reader, Front and Back Covers: passo 1, immagine 1 di 3 Canon PowerShot A550 SD Card Reader, Front and Back Covers: passo 1, immagine 2 di 3 Canon PowerShot A550 SD Card Reader, Front and Back Covers: passo 1, immagine 3 di 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Canon PowerShot A550 SD Card Reader: passo 2, immagine 1 di 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Canon PowerShot A550 SD Card Reader: passo 3, immagine 1 di 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Canon PowerShot A550 SD Card Reader: passo 4, immagine 1 di 2 Canon PowerShot A550 SD Card Reader: passo 4, immagine 2 di 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Canon PowerShot A550 SD Card Reader: passo 5, immagine 1 di 1
    • The camera should look like this once the front cover is removed.
  6. Canon PowerShot A550 SD Card Reader: passo 6, immagine 1 di 3 Canon PowerShot A550 SD Card Reader: passo 6, immagine 2 di 3 Canon PowerShot A550 SD Card Reader: passo 6, immagine 3 di 3
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Canon PowerShot A550 SD Card Reader: passo 7, immagine 1 di 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. Canon PowerShot A550 SD Card Reader, SD Card Reader: passo 8, immagine 1 di 3 Canon PowerShot A550 SD Card Reader, SD Card Reader: passo 8, immagine 2 di 3 Canon PowerShot A550 SD Card Reader, SD Card Reader: passo 8, immagine 3 di 3
    • Remove two 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
    • Caution: Do not tug on the LCD screen. This will tear the ribbon connecting the LCD screen to the body of the camera.
    • Loosen the black ribbon clamp using an iPod opening tool
    • Release the LCD screen by removing the ribbon from the body of the camera.
  9. Canon PowerShot A550 SD Card Reader: passo 9, immagine 1 di 2 Canon PowerShot A550 SD Card Reader: passo 9, immagine 2 di 2
    • Unscrew 2 3.35mm phillips head screws from the face of the green circuit board using a #00 phillips head screwdriver.
    • Caution: Do not tug on the circuit board. This will tear the ribbon connecting the circuit board to the body of the camera.
  10. Canon PowerShot A550 SD Card Reader: passo 10, immagine 1 di 3 Canon PowerShot A550 SD Card Reader: passo 10, immagine 2 di 3 Canon PowerShot A550 SD Card Reader: passo 10, immagine 3 di 3
    • Release the black ribbon clamp using an iPod opening tool to lift it.
    • Remove the ribbon connecting the circuit board from the body of the camera using tweezers.
    • The SD card reader is attached to the back of the circuit board. The circuit board and SD card combination should be replaced.
Conclusione
Cal Poly, Team 8-6, Regan Spring 2011 Membro di Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,913
