Introduzione
Involving removal of the camera casing as well, this guide will help the user remove the LCD screen to repair or replace it.
Parti
Nessuna parte richiesta.
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
  • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
  • While still holding the switch, pull the cover down, allowing it to release and open.
Aggiungi Commento
Tilt the camera slightly to allow the batteries to fall out.
  • Tilt the camera slightly to allow the batteries to fall out.
Aggiungi Commento
Press on and release the memory card to eject it.
  • Press on and release the memory card to eject it.
Aggiungi Commento
Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
  • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
  • Make sure to keep the different size screws organized to make reassembling the camera simpler.
Aggiungi Commento
Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
Aggiungi Commento
Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
Aggiungi Commento
Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
Aggiungi Commento
Remove the second battery cover on the bottom of camera. Take the silver battery out of the camera.
  • Remove the second battery cover on the bottom of camera.
  • Take the silver battery out of the camera.
Aggiungi Commento
Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots. Remove the light grey, plastic piece. Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
  • Remove the light grey, plastic piece.
  • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
Aggiungi Commento
Slightly pull on each side of the camera. It should loosen up and come apart. If it does not pull apart right away, use a little more force. Do not give up!
  • Slightly pull on each side of the camera. It should loosen up and come apart.
  • If it does not pull apart right away, use a little more force.
  • Do not give up!
Aggiungi Commento
Remove the back case of the camera by pulling from the top.
  • Remove the back case of the camera by pulling from the top.
  • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
Aggiungi Commento
Remove the 4mm Phillips #00 screw from above the ribbon.
  • Remove the 4mm Phillips #00 screw from above the ribbon.
Aggiungi Commento
Gently peel off the blue tape on the top of the LCD screen.
  • Gently peel off the blue tape on the top of the LCD screen.
Aggiungi Commento
Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
  • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
Aggiungi Commento
Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
  • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
Aggiungi Commento
Using a spudger, lift the grey tabs to allow the ribbon to slide out.
  • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
Aggiungi Commento
Since the tabs have been lifted, the ribbon should now slide out out easily.
  • Since the tabs have been lifted, the ribbon should now slide out out easily.
  • Be careful not to distort the ribbon in any way.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Alex
Membro da: 18/01/2013
67 Reputazione
2 Guide realizzate
Cal Poly, Team 19-42, Regan Winter 2013 Membro di Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Membri
6 Guide realizzate
Thanks for this super documented guide.
I did it!! I found a second hand lcd on Ebay.
Now my camera is working again.
Super DIY guide!! Thanks a lot!!
Pierre - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 876
