Salta al contenuto principale
Canon PowerShot A1000 IS Case Disassembly
Cosa ti serve
  1. Canon PowerShot A1000 IS Case Disassembly, Canon PowerShot A1000 IS Case Disassembly: passo 1, immagine 1 di 3 Canon PowerShot A1000 IS Case Disassembly, Canon PowerShot A1000 IS Case Disassembly: passo 1, immagine 2 di 3 Canon PowerShot A1000 IS Case Disassembly, Canon PowerShot A1000 IS Case Disassembly: passo 1, immagine 3 di 3
    • Transfer screws to a safe place upon removal.
    • The case is held together with two types of screws: fine thread screws that attach the case to the metal parts below, and coarse thread screws that attach the case to the plastic battery compartment.
  2. Canon PowerShot A1000 IS Case Disassembly: passo 2, immagine 1 di 2 Canon PowerShot A1000 IS Case Disassembly: passo 2, immagine 2 di 2
    • Remove the two coarse thread screws on the side of the device, to the left of the camera lens.
  3. Canon PowerShot A1000 IS Case Disassembly: passo 3, immagine 1 di 2 Canon PowerShot A1000 IS Case Disassembly: passo 3, immagine 2 di 2
    • Remove the two fine thread screws on the side of the device, to the right of the camera lens.
  4. Canon PowerShot A1000 IS Case Disassembly: passo 4, immagine 1 di 3 Canon PowerShot A1000 IS Case Disassembly: passo 4, immagine 2 di 3 Canon PowerShot A1000 IS Case Disassembly: passo 4, immagine 3 di 3
    • Remove the two coarse thread screws and the single fine thread screw from bottom the camera.
  5. Canon PowerShot A1000 IS Case Disassembly: passo 5, immagine 1 di 2 Canon PowerShot A1000 IS Case Disassembly: passo 5, immagine 2 di 2
    • Remove the one coarse thread screw underneath the battery cover.
  6. Canon PowerShot A1000 IS Case Disassembly: passo 6, immagine 1 di 3 Canon PowerShot A1000 IS Case Disassembly: passo 6, immagine 2 di 3 Canon PowerShot A1000 IS Case Disassembly: passo 6, immagine 3 di 3
    • Gently pry apart the two covers starting from the bottom. When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover, to release the three catches that secure the shell.
  7. Canon PowerShot A1000 IS Case Disassembly: passo 7, immagine 1 di 2 Canon PowerShot A1000 IS Case Disassembly: passo 7, immagine 2 di 2
    • Gently remove both sides of the casing.
  8. Canon PowerShot A1000 IS Case Disassembly: passo 8, immagine 1 di 2 Canon PowerShot A1000 IS Case Disassembly: passo 8, immagine 2 di 2
    • When replacing the cover, remove the AV/USB rubber cover for easier reconstruction.
    • Replace the front cover first leaving a small gap on the left hand side of the device for easy reattachment of the back cover.
    • Reattach the back cover by aligning it with the front cover and snapping the latches into place. Secure with screws in any order.
Conclusione
Altre 2 persone hanno completato questa guida.
Biff Wheeler
Membro da: 06/06/12
762 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,274
