Start by removing the case in the previous guide. The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver. The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver.
  • Start by removing the case in the previous guide.
  • The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Once the spring is clear of the plastic, you can easily push the dowel through with a pin, the end of the tweezers, or a paperclip. Grab the dowel from the other end and pull it out. Grab the dowel from the other end and pull it out.
  • Once the spring is clear of the plastic, you can easily push the dowel through with a pin, the end of the tweezers, or a paperclip.
  • Grab the dowel from the other end and pull it out.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Biff Wheeler
Membro da: 06/06/2012
738 Reputazione
4 Guide realizzate
Hi I have the camera of same model A1000.
Where can I get the battery cover, mine is broken?
Please share the details.
Chennakeshava Reddy Palla - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,312
