Introduzione
The AC adapter may need to be replaced if you are experiencing issues with the power connection to your printer. The removable power cord is plugged into the AC adapter.
It is very important to disconnect your printer from the outlet before attempting replacement. This ensures that there is no power reaching the AC adapter. Remove power cord by disconnecting it from the AC Adapter.
  • It is very important to disconnect your printer from the outlet before attempting replacement. This ensures that there is no power reaching the AC adapter.
  • Remove power cord by disconnecting it from the AC Adapter.
Aggiungi Commento
Pinch upper and lower prongs, moving them away from the AC adapter. Pinch upper and lower prongs, moving them away from the AC adapter.
  • Pinch upper and lower prongs, moving them away from the AC adapter.
Aggiungi Commento
The AC adapter will now be loose, and able to come away from the printer. Grasp the AC adapter and pull it toward you to remove it.
  • The AC adapter will now be loose, and able to come away from the printer.
  • Grasp the AC adapter and pull it toward you to remove it.
Aggiungi Commento
Rotate the AC adapter toward you so that the blue cord, with white connector head, is facing you.
  • Rotate the AC adapter toward you so that the blue cord, with white connector head, is facing you.
Aggiungi Commento
Grasp the white connector head that is attached to the end of the blue cord. Disconnect the white connector head by gently pulling it away from the AC adapter. You have successfully removed the AC adapter.
  • Grasp the white connector head that is attached to the end of the blue cord.
  • Disconnect the white connector head by gently pulling it away from the AC adapter.
  • You have successfully removed the AC adapter.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Caitlyn
Membro da: 07/10/2014
506 Reputazione
4 Guide realizzate
USF Tampa, Team 1-3, Leahy Fall 2014 Membro di USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 Membri
4 Guide realizzate
Does anybody know the pin-out for these power supplies?
James Rudee - Replica
WHERE CAN I BUY AC ADAPTER PIXMA GM 5220 PRINTER ? PLAESE !! my cell 678 899 1187, 770368 0409 w
vincent lieu - Replica
Well I’ve just taken the AC Adapter out - I’ll let you know if a the replacement works once I’ve purchased it - Which I am hesitant to buy in case that’s not the problem.
The printer is barely 2 years old and barely used, I shouldn’t be experiencing this problem of the printer not turning on.
Canon you need to get your act together if you would like to stay in business, I’m seeing a lot of comments on this problem over a range of different printer models - Mine is a Pixma iX6860.
rezidraft - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 38
Tutti i Tempi: 1,961
