Salta al contenuto principale
Canon PIXMA MP620B Command Screen Replacement
Cosa ti serve
  1. Canon PIXMA MP620B Command Screen Replacement, Open Printer Lid: passo 1, immagine 1 di 1
    • Open top lid of the printer to reveal the scanner
  2. Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: passo 2, immagine 1 di 2 Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: passo 2, immagine 2 di 2
    • Insert the spudger tool into the top lid in between the blue and the black panels.
    • Use this tool to pry the two panels apart
  3. Canon PIXMA MP620B Command Screen Replacement, Take apart the two sections: passo 3, immagine 1 di 1
    • After these two panels are separated, set the top panel to the side for now
  4. Canon PIXMA MP620B Command Screen Replacement, Pull out wires leading to screen assembly: passo 4, immagine 1 di 1
    • Unplug the two wires shown at the right of the command screen
  5. Canon PIXMA MP620B Command Screen Replacement, Unscrew screen assembly: passo 5, immagine 1 di 1
    • Unscrew the four screws shown to detach the command screen from the printer
  6. Canon PIXMA MP620B Command Screen Replacement, Replace assembly: passo 6, immagine 1 di 1
    • Take the detached command screen off of the printer and replace.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 6-21, Maness Fall 2014 Membro di Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
4 Membri
10 Guide realizzate
2 Commenti
Ideas as to where to buy replacement screen assembly?
davepi49 - Replica
same question
Jan de Ruiter -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,306
