Salta al contenuto principale
Canon ImageCLASS MF4350d Scanner Belt Replacement
Cosa ti serve
  1. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Disassembly: passo 1, immagine 1 di 1
    • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
    • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
  2. Canon ImageCLASS MF4350d Scanner Belt Replacement: passo 2, immagine 1 di 3 Canon ImageCLASS MF4350d Scanner Belt Replacement: passo 2, immagine 2 di 3 Canon ImageCLASS MF4350d Scanner Belt Replacement: passo 2, immagine 3 di 3
    • Locate the black and white hinges.
    • Gently lift out the black and white hinges.
  3. Canon ImageCLASS MF4350d Scanner Belt Replacement: passo 3, immagine 1 di 3 Canon ImageCLASS MF4350d Scanner Belt Replacement: passo 3, immagine 2 di 3 Canon ImageCLASS MF4350d Scanner Belt Replacement: passo 3, immagine 3 di 3
    • Next, locate and remove the four 10mm screws.
  4. Canon ImageCLASS MF4350d Scanner Belt Replacement: passo 4, immagine 1 di 1
    • Gently, pry off the top plate, starting from the back of the printer.
  5. Canon ImageCLASS MF4350d Scanner Belt Replacement: passo 5, immagine 1 di 2 Canon ImageCLASS MF4350d Scanner Belt Replacement: passo 5, immagine 2 di 2
    • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
  6. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: passo 6, immagine 1 di 2 Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: passo 6, immagine 2 di 2
    • Remove the black component by gently pulling it up from the black scanner belt
  7. Canon ImageCLASS MF4350d Scanner Belt Replacement: passo 7, immagine 1 di 2 Canon ImageCLASS MF4350d Scanner Belt Replacement: passo 7, immagine 2 di 2
    • Press down on the white release and force it in toward the spring as shown. While you do this, pull the scanner belt out of the track.
    • Take a new belt and put it in the same way that you took it out.
Conclusione
Cal Poly, Team 13-1, Forte Fall 2013 Membro di Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,849
