Introduzione
Use this guide to replace the interior eyepiece of the camera.
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
Aggiungi Commento
On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
  • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
  • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
Aggiungi Commento
Remove three medium length screws from the bottom of the camera
  • Remove three medium length screws from the bottom of the camera
Aggiungi Commento
Remove the two medium length screws on the front panel of the camera above the lens mount.
  • Remove the two medium length screws on the front panel of the camera above the lens mount.
  • Once you done, you may use the Spudger to panel from non-grip side.
  • If you start on the grip side, it will be more challenging to loosen the panel.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
  • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
  • Use tweezers to lift the panel.
Aggiungi Commento
Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
Aggiungi Commento
Remove the following ribbons with the tweezers by gently pulling on them.
  • Remove the following ribbons with the tweezers by gently pulling on them.
  • Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
Aggiungi Commento
Remove the cable heads attached on the front side of the camera next to the lens mount.
  • Remove the cable heads attached on the front side of the camera next to the lens mount.
  • Be gentle when puling wires lose, use the tweezers to remove the wires.
Aggiungi Commento
You can use your fingers to pull the top panel of the camera.
  • You can use your fingers to pull the top panel of the camera.
Aggiungi Commento
After removing the top panel, you can use your fingers to remove the eye piece from the camera.
  • After removing the top panel, you can use your fingers to remove the eye piece from the camera.
Aggiungi Commento
Conclusione
Daniel Bussone
Membro da: 28/01/2011
1.206 Reputazione
11 Guide realizzate
Cal Poly, Team 3-41, Regan Winter 2011 Membro di Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Membri
11 Guide realizzate
Is there a part number to order the interior eyepiece? It does me no good to take it apart if I don't have or can't find a replacement for it.
Erik - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 6,090
