Salta al contenuto principale
Canon EOS Rebel T5 SD Card Replacement
Cosa ti serve
  1. Canon EOS Rebel T5 SD Card Replacement, Battery: passo 1, immagine 1 di 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 SD Card Replacement: passo 2, immagine 1 di 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 SD Card Replacement, SD Card: passo 3, immagine 1 di 1
  4. Canon EOS Rebel T5 SD Card Replacement: passo 4, immagine 1 di 1
    • Open the battery compartment by lifting the card/battery door. You will see a thin SD Card slot below the battery.
    • Push in the old SD card until it clicks to remove it and then push in the new card until it clicks into place.
Conclusione
Altre 3 persone hanno completato questa guida.
Austin Tucker
Membro da: 08/27/15
1.027 Reputazione
4 Guide realizzate
USF Tampa, Team 16-4, Wollert Fall 2015 Membro di USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 33
Tutti i Tempi: 3,206
